Was it working previously? If so, did you happen to smell any strange smells around the time it stopped working? Of course, as always, best first way to check is to load up one of the example files that came with the printer and test with that. If still no heat, you may have experienced the power connection problem that haunts these things. Connections aren’t rated for the amperage, causing them to burn/melt/etc.
If it reports “0C” then it is the sensor or the wiring to the sensor and not the heater. It should read your room temperature if the sensor works. The bed will not heat if there is a sensor issue (for safety). I really recommend modifying the printer since a replacement will probably do the same thing after enough time. This is a printer that really requires a few mods to reach full potential.
