Hi all,
Just joined your site after doing a lot of research on it looking for a solution to my problem. I am hoping someone can help but my guess is I will need to return this printer. Again, the first one I got had a bad motor. Just got the new one and when I hit Home All, the Print head is where it is supposed to be, front left corner. But the bed moves all the way to the back. Meaning that the print head is at home postilion but not over the bed. I feel like the bed was installed backwards or wired in reverse. Thoughts? Going to be super annoyed if I have to return another one. I purchased it a month ago now and haven’t got use it.
Can you provide a picture of where the print head sits when you press “Home All”?
It is possible the stepper motor was plugged in backwards. However, you should be able to
reverse the settings via gcode commands.
I took it apart and put it all back together and now it works. not really sure what it was because I didn’t replace anything.
Hi, My MP Select Mini V2 has the same issue, the print nozzle isn’t over the print bed when i home all axis. I am trying to figure out the same thing.
