I had some similar issues with layers shifting and it turned out to be my extruder shifting position as the layer height grew. I ended up pulling the extruder to the side with a ziptie, so the slop was eliminated.
Do you have a picture of this zip tie mod? Thanks!
added the fan and slowed down the rate. Improved quality but there are still some issues in the same spots. Just not as dramatic. I’ll have to play around with the speeds. Thanks!
I added the fan except its just always on right now. I don’t have the mosfet or a switch yet. I just jam the fan with a piece of PLA until the first few layers are done and then take out the stopper. Print quality is up but not to my satisfaction. It seems like from this point it is guess and test. Thanks for the help thus far.
If you have a look at my guide you can see how to remove slack from the x and y carridge it’s over on CTC talk under IGUS bearings
Update: I added a cooling fan and slowed down my feed and travel rates. Overall print quality increased.
Current settings are:
Infill: 15
Shells: 2
Layer height: 0.1mm
L Temp: 230
R Temp: 205 (Tried 200-220)
Bed: OFF
Extruding Speed: 40
Traveling Speed: 50
I’ve tried combos of 215/30/30, 215/40/80, 205/40/80, 200/40/60, 205/40/50 with numbers representing Extruder_Temp/Extruding_speed/Travel_Speed.
I am still having issues between Marvin’s legs (hehe), his “ears” not being round, his lower back not being uniform, and the V-region on the front of his face not coming out too well.
Are the errors I’m seeing indicative to a particular setting or do I just need to power through and try more combinations?
Thanks for all the community support thus far!
Me toooo , the sam happened
Are you using RepG for software? The slicer it uses isn’t that great, I also would recommend MakerWare (it’s free) and super user friendly and easy to use. You could also add in another shell to make it 3, it’s another inner layer of support.
Nice one! I’ll link everyone to it: Talk Manufacturing | Hubs 3
Makerware for what it is, is terrible there’s no brim and only recently the addition of some access at custom profiles if you want a nice print I can send you a Marvin print sliced through simplify 3d and I never have managed to get a perfect Marvin around the back as it just is a steep overhang
I’m using Makerbot Desktop 3.4.1.48 with the stock firmware on the actual printer (not sailfish)
That would be great if you could. Can you also provide the settings for your file. Thanks. etang858@gmail.com
Emailed you
Try some different filament. I’ve seen drastic differences between brands. Ultimachine, maker gear and hatch box I’ve heard good things about. Also print 4 at a time, this will allow for more cooling time regardless of a fan.
