Jan 2016
This is my 1st 3d printer and I have many problems with this. I use the Repetier host for FELIXprinters v 1.0.6
1. The default settings do not work. I have tried slic3r and curaEngine and each of them are absolutely not suitable for my printer, can’t print even the simplest model.
2. My settings are a little not suitable. When I tried to improve the print quality, the first layer of the model was printed wavy lines (see photo)
Please, help me
    Jan '16
    Nov '16
  • 15
  • 4.9k
  • 9
Hello kRRRio, for me it looks like your z-height is too high. You can also see that the lines are not touching each other. Did you calibrate your z-height good enough. The distance between the bed and the extruder should be that it’s scratching a piece of plane paper but not tearing it.
Try to make the first layer thicker, like 0.3mm. Try to print 0.2 mm layers (not 0.1mm). Try to print the first layer slow (33% speed).
Hi
I know that behavor just too well. What did I do ? Try leveling the bed as good as you can. It is very difficult because there are just 3 points to adjust (instead of all 4 corners). Find on Thingiverse the bed level stl for Felix. It helps you to identify where its too high or too low. My Aluminium bed is definitly uneven (a very little bit).
After (or while) that level the Z axle (as mentioned by others). Now, I know it´s hard to be patient, but it will help you to save filament and frustration if you lower the printing speed. Please try 30%. It will take like forever, but the slower the print is, the better the result is. My Felix 3.0 is also pulling a little bit too much filament, so I reduced to 98 % flow.
I print the first layer with 195 degrees, but then with only 185 degrees. 200 or more is absolutly no improvement.
I´ve seen that the model is quite big. Try something small (but flat) first, than something bigger and only if that worked for satisfaction print the big thing you have.
Good luck :slight_smile:
bye
I think your problem is that your extrusion width is smaller than the nozzle diameter. It is better to start with the default setting of Slic3r and see how that is going. I always print my first layer 0.8 mm wide ,perimeters 0.48 and the infill 0.72 with a 0.35 nozzle. Because of the wide extrusion of the first layer the filament really gets squashed on to the bed.
This works fine on my Felix Pro 1, even though the bed is 0,05mm unflat.
MATERIAL
PLA
200°C first layer
190°C consecutive layers
BED
kapton bed, cleaned with alcohol or ammonia
55°C bed temperature
nozzle distance is about 1 layer of paper (0,1mm)
EXTRUSION
0,35mm nozzle
0,4mm extrusion width
0,25mm first layer
120% extrusion on first layer
Very useful comment @Vienna3DPrint! It is definitely true: calibrating the bed requires patience but it is more than worth it to prevent failed prints and to not waste any filament.
Just to make sure: it is very important to clean the bed properly before every print job with denatured alcohol. Not cleaning the print bed may lead to poor adhesion.
Also: thicker layers (standard 0.2mm layer height settings) will have better adhesion to the print bed than 0.05 mm layer height. It is perhaps worth trying to print with the standard settings to see how it goes!
10 months later
