obj/src/core/application.cpp:166: error
Application::Application(int *, char **, const QString &, const QString &, const MakerBot::Version &)
Fri Oct 7 21:39:04 2016
Exception : Unable to connect to: /var/tmp/conveyord.socket
obj/src/util/log.cpp:41: error
void logQtMessage(const QtMsgType, const QMessageLogContext &, const QString &)
QtWarningMsg: QSslSocket: cannot resolve TLSv1_2_server_method(?:0, ?)
Fri Oct 7 21:39:08 2016
QtWarningMsg: QSslSocket: cannot call unresolved function SSL_get0_next_proto_negotiated(?:0, ?)
should I look for thoe named “error”?
I also have the last two in my logs for SSL connection but don’t have the first one. When I open Makerbot Desktop, I can see /var/tmp/conveyord.socket in the terminal. Open your terminal and go to that folder, check if it’s there? conveyord.socket is a file
Ok if I write: sudo rm /var/tmp/conveyord.socket or sudo rm /var/tmp/conveyord.pid i get “No such file or directory”.
Inside my Library/LaunchDaemons i have a file called “com.makerbot.conveyor.plist” however.
Are you logged in as an Admin (root) to your mac? those are temporary files that should be re-created when you open Makerbot Desktop app if deleted. That first error was complaining about the conveyord.socket . Probably the background service or the app cannot create that file, or because the service is not running that file is not being created. Create that file manually like a text file and see if that first error goes away.
I am not sure how i should do that. Should I create it in the logs and inside the latest file there? Damn this is pretty hard :stuck_out_tongue: I expected it to be much easier. Myabe I should just downgrade to El capitan (it worked there before i updated to mac os sierra).
:smiley: if you are not familiar with Linux then it’s going to be really hard to fix it. If there is nothing special in Sierra for you to use then go ahead and re-install El capitan :wink:
Hi to all,
Happened to me in ubuntu. I have a temp fix that works every time. It may spark an idea for your OS X to get fixed.
  1. /var/lock/conveyor folder is NOT being created. -> Create it with 777 rights.
  2. /var/lock/conveyor/conveyord.socket is NOT being created. -> Create the file with 777 rights.
  3. Wait 5-8 seconds
  4. Stop “background service” from makerbot software.
  5. Wait 5-8 seconds
  6. Start “background service” from makerbot software.
  7. Wait 5-8 seconds
You will see the service would start and makerbot software would find the printer and show “printer ready”
Hope this helps.
Same problem. I reinstalled MakerBot for Mac. Now works fine.
Yes, same problem here, trying to start makerbot and slice with makerbot Software, i get the message backgroundservice not available and i could not do anything. i tried to reinstall an old version and also a newer version of makerbot, but nothing happened. Going back to an older OS on my mac is no solution for me. Any suggestions?
