Feb 2016
Hi Anthony,
the problem is how are you storing the filament, it has to be dry, pla absorbs humidity
I try to change the diameter settings of the fillament.
By Increasing it to 1.8 it prints perfect now.
Prob not the solution in all cases. but it worked for me !
Switch of retraction and see if it keeps working then. You will have stringing then, but at least you know then that retraction contributes to it, and you can play with that setting.
Also, did you clean the gear that pushes the filament in? I dissassemble that and clean the gears with toothpick if traction starts to fail.
I had the same problem as Andy explained I lowered my warmup temp to 200c and my print temp is 220c or less. Haven’t had any problems since. (also replaced the heating block at the same time as dropping the temp to make sure no extra goop inside would mess with it)
