May 2017
14 days later
i find the best way to have no issues with the m bot is to leave it in the corner under the dust cover myself they also just about to bump there spares up to by 20% its not like there cheap anyhow incase u havent had the heads up on that. … click click crunch on every start up :'l
Hi Wayne,
I noticed that you mentioned Simplify3d to control your makerbot, I have a Replicator 5th Gen but cannot get Simplify3d to connect or control the MB through USB cable at all. I have setup S3D with the required MB firmware.
Or are you perhaps outputting .stl files and running through a USB stick or SD card ? Any advice you could give would be most appreciated! thanks
You can use simplify3d to output sliced files for a USB stick. This is the best way since Simplify3d is not yet supporting newer firmwares. Simplify3d will output a .makerbot file.
Thanks 360alaska, do you know if the .makerbot file carries over all the temperature and specific layer speed/temp settings that I set in S3D?
yeah mate, just export to usb and walk it to the machine. Simplify3d really steps up the game on the makerbot Z18, there just isn’t a comparison to mb desktop.
a .makerbot is just a zip archive that contains the gcode, text file and the thumbnails.
hey mate,
more than happy to share the s3d profile for my mb z18, I’ll flick you an email and help you get it sorted.
