Jan 2016
Hi all,
I’m using Makerbot Desktop Beta v. 3.8.1.168.
Dual extruder makerbot clone but only printing using one extruder and PLA.
When I print, the actual extruder head moves faster when printing support material than when printing model material. Its moving too fast, and I don’t always get good support material adhesion. Model material adhesion is fine on the same layer because the physical extruder head travels slower.
Is there a way to slow down how fast the extruder head travels during support extrusion?
Thanks for all the help!
1 month later
Have you tried downloading prof tweaks fro mnothign labs and adjusting the speeds for the support material? You can adjust the speeds for about 6 different things like rafts etc. I dont know much about it as i’m quite new to this but its possible through proftweaks.
Im having the same problem. Did you find a solution? I think the software Richard_Blackwe suggested was created for earlier versions of makerbot Desktop i.e Makerware because settings were limited at the time. I dont think it has an entry for support speeds.
The solution is to upgrade to Makerware 3.8 - this gives you control over all of the speeds in the settings area. I found this out since writing my oringial reply. Also, if you are using the PLA that came with the CTC, you need to use a temp of 222c
I am currently using makerbot desktop 3.8. However there is no entry for setting support speeds? I am looking under Settings > Extrusion speeds. All I see are bridges,first layer, first layer rafts, infill, insets, outlines, raft and raft base but nothing for supports. I might be missing something. Let me know! Thanks!
17 days later
actually I have noticed in mine, that setting every speed to 10mm/s doesnt change the actual speed in my CTC, it still printes at 30-40mm/s , noticed this with replicatorG at 10/s that is really slow, ithink I will try older software versions
