Yeah, if you are going to use filaments other than the M3D filament you should look into using octoprint. At least then you can use sli3er to really tweak the filament to your liking and then send it over to the printer. Basically all you need for super simple set up is a raspberry pi, the latest octopi image (OctoPrint.org - Download & Setup OctoPrint 4) and the M3d fio plugin (GitHub - donovan6000/M33-Fio: The ultimate OctoPrint plugin 2) Seriously simple if you can read and follow instructions.
I’v been using open source filiment for about a year on my micro. But to be careful I used colour fab first before using cheap Chinese filements with odd temperature recommendations. Since the micro is preset to 215 degree’s unless you don’t change the temperature setting with expert mode. Inconclusion you have probably accidentally used ABS or a filiment other than PLA causing all your issues.
I tried installing octoprint on a orange Pi since it is so much cheaper but failed to get the pi to even turn on so I tried the computer version but failed Iv just been using TeamViewer at the moment so I can start prints from my iPad
anyway would mind trying computer octoprint again is their a suitable tutorial
Hate to love being that guy but:
1. The orange pi is more expensive than the Raspberry…
2. The orange pi didn’t turn on because the image is for a raspberry pi.
3. I doubt you will find a tutorial, ever, for the orange pi and octoprint specifically.
4. There are suitable tutorials out there, you only needed to look at the instructions for installing on linux (from source) Home · OctoPrint/OctoPrint Wiki · GitHub
5 suggestions.
1. I would suggest purchasing an IR thermometer before reaching the conclusion that there is a temp problem.
2. As suggested below, be sure that you are using the correct type of filament (ABS, PLA etc) and their coresponding temperature profiles.
3. It’s worth purchasing the spare nozzle from the M3d website. It is far superior in heat distribution that the one your printer shipped with.
4. If you have a multi-meter, test to make sure your adapter is actually putting out the rated Amperage.
A better example would be of the same print with both filaments instead of 2 different prints. You can use slicer to cut the model ( and export as STL if you are using the official software) and only print the top 20 layers or so. I would probably raise the temperature for your darker filaments to increase flow.
