Jun 2016
Hi
The simple test I did was…
1) put on 2 x 1KG rolls of filament on the bed to test stability whilst moving and z Axis movement.
2) put on 1KG roll of filament right at the front of the bed mid print and observed 0.9 mm of movement in the layer.
given the machine could easily move with 2 kg and only 0.9mm of movement was evident the layer when 1kg of weight was added mid print, over the coarse of a large print the incremental weight increase would easily dissipate through the layers with no adverse affect. Please also bear in mind the 1kg was added right at the front edge of the bed giving an uneven weight distribution, (thinking on worse case scenario).
The z axis guide rods operate independently from the Y and X Axis and are using 12mm rod and bearings
Thanks for the question and hopes this helps to answer it.
When do you expect to have the instructable ready? I own three printers already, but I’m ready to build my own, and this is the one.
Thanks for your support.
instructable should be published shortly.
Hi Mikkel
No programming required as such.
The beauty of this project is it uses the smoothieware firmware and a simple configuration file which is edited in notepad or other simple txt format.
Thanks
