Wamd
June 1, 2016, 7:21pm
11
Thanks
I did think it would be cool if you could buy this from ikea in a kit.
Wamd
June 1, 2016, 7:23pm
12
I spent £260 and am currently constructing the instructable one for under £200
Wamd
June 1, 2016, 7:25pm
14
Will do, cheers for the comment
How is the bed being supported with larger or heavier prints?
Wamd
June 1, 2016, 11:27pm
16
Hi
The simple test I did was…
1) put on 2 x 1KG rolls of filament on the bed to test stability whilst moving and z Axis movement.
2) put on 1KG roll of filament right at the front of the bed mid print and observed 0.9 mm of movement in the layer.
given the machine could easily move with 2 kg and only 0.9mm of movement was evident the layer when 1kg of weight was added mid print, over the coarse of a large print the incremental weight increase would easily dissipate through the layers with no adverse affect. Please also bear in mind the 1kg was added right at the front edge of the bed giving an uneven weight distribution, (thinking on worse case scenario).
The z axis guide rods operate independently from the Y and X Axis and are using 12mm rod and bearings
Thanks for the question and hopes this helps to answer it.
When do you expect to have the instructable ready? I own three printers already, but I’m ready to build my own, and this is the one.
Looks good. I did the same, building an enclosure for an Prusa i3. Not as nice as what you have setup though. Great job.
Wamd
June 3, 2016, 7:32am
19
X 10 Marvin 0.5 layer height, No infill ,No Support 0.6 Nozzle 6.hrs 40 minutes
WOW very COOL …
If you want to buy powerful & cheap 3D Printer… auto leveling
(NO MORE wasting TIME - 30sek. & Ready To Go)
super basic to use Cura 3D Printing Slicing Software …MICROMAKE D1 … https://youtu.be/kXie0oyaHKo
That is huge and looking good. Looking forward for the £260 Guide and BOM.
Wamd
June 3, 2016, 7:48pm
22
Thanks for your support.
instructable should be published shortly.
Wamd
June 3, 2016, 7:49pm
23
Many thanks.
instructable will be published shortly.
Are the BOM list hard to find?
Wamd
June 4, 2016, 9:24pm
26
All being well I hope to have the instructible published with in the next 10 days.
sorry if that’s a bit long but given the amazing interest this project now call PRINTTABLE is generating I want to ensure the instructible as easy to follow as possible.
Thanks for interest and comments and please build one as soon as it’s published.
Wamd
June 4, 2016, 9:33pm
27
Most of the parts are available relatively easy. All parts will be available at the currently under construction site PRINTTABLE.com . The core premise is a total open source project at its core building on a worldwide common platform being the LACK Table range. The more modifications,developments and enhancements made the more the community will benefit.
thanks for the interest and your support.
looking forward to the instructables…don’t forget 2 add a donate me button
Any update on an instructables? will it be on instructables.com ?
Wamd
June 10, 2016, 12:41am
30
We will be working hard over the weekend in an attempt to publish on Monday.
Please check out our preview. Printtable Short - YouTube
Our aim is to ensure the instructable is easy to follow.
Thanks for your patience.
