May 2015
Hello,
I have experience with SLS- Printing only.
Is this Tower printable by FDM?
Wall thickness = 2 mm / Windows cross = 0,8mm
Max diameter = 156
Hight = 350mm
Does somebody has samples, how this could look like after printing?
Hi there! Yes this shold be printable, do you have material preferences or any other wish for color/property of this object? The lines in the Windows are 0,8mm thick, right? Please contact me by creating an enquiry on my hub, because I have some other questions to clarify before being able to print this. If you consider shipment to be an issue I can guarantee you, that this is no problem. I ship worldwide for a maximum of 15€ and have fair pricing for a wide variety of materials. Here’s the link to my hub: www.3dhubs.com/siegen/hubs/marius If preferred you can also contact me via Skype: Nickname: railes123 Kind regards, Marius Breuer
The main learning on my side: Pulling out the support from the windows is somewhere near impossible. So I’m currently printing a wall with two windows again without support material. This would probably be the strategy for the final print too then, prevent auto-generation of support material for everything except holding up the brim of the roof :smiley:
Well, it is possible to pick out the support from the windows, but it doesn’t leave a nice result and it’s a very gruesome task, wouldn’t really want to do it for a whole tower :smiley:
Cleaning up the roof however is pretty straight forward, just did a piece of that and this is the end result.
A bit more details :slight_smile:
As you can see the layers are quite distinquishable with FDM. There is the possibility to do a acetone vapor bath to smooth the surface if the print is ABS. Otherwise the layers will always be there.
With a resolution of 100microns this is somewhere between Medium and High Resolution on 3D Hubs. As for the cleanliness I guess there are printers that do fare better on FDM. But the overall Texture will stay.
That’s what I was expecting. Coming from an SLS process the lines created by an FDM print (as small as they might be overall - there are printers that print finer than what I can do with mine and overall can create a cleaner print due to better ooze prevention) are just not as nice as the grainy look and feel from an SLS print where the part is always naturally supported by the not bonded material and thus has perfect finish all around with no supports needed and nothing to remove.
The only real advantage of FDM vs SLS is cost of manufacturing.
