Like if the fail rate was 8.0, would that mean it fails a lot or doesn’t fail that often?
you want a low failure rate.
The failure rate is how often a print does not finish (scrap part and have to start again), so if you had say a failure rate of 1 in 100 compared with 50 in 100, it is by far more preferable for the 1 in 100.
Rated 4.7??? what do they want for a Single colour Print with a 0.05Nozzel??? at 0.1 mm it was giving the Best prints for a Persa Mendel with a 0.05mm Nozzle I have the 0.035mm but you have to set it so high you burn PLA and Gob ABS Is it one to One YES
