first I hope when you took off the nozzle that you follow the procedures some people have put on indestructibles where you need to heat up the nozzle first otherwise if you didn’t do that you might have ruined some of the threads where the PLA is actually coming out the side like you mentioned is the plastic still coming out of the nozzle fine though because when I had a problem like it coming out of the side it was not coming out of the nozzle and there was some blockage not in the nozzle but in the threaded to between the heater block and the motor assembly that had to get cleaned out I ended up getting a full replacement part from MakerBot because I contacted the help desk and had some maker care
Hello Logan,
You probably need to change the nozzle of the heating block. Something is loose there.
I don’t know where you are located (we’re in Montreal), but you can bring it to our store and we can fix it. Or we’ll buy it from you.
Good luck!
Claudia
Hi, i cant see anything strange form the picture, except that there are two nozzles, but the Replicatro2 hat only one
Is its a Replicator2x forget printing PLA (unless u “upgraded” your extruders). Which one you you have, 2 or 2x ?!
otherwise i would suggest to check here for Replicator2 faq: MakerBot CloudPrint™
or here for Replicator2x: MakerBot CloudPrint™
the nozzles look as if they where never used, so i dont know. maybe you should have a look at the maintainance guide first
and see if you did everything already. Its very important to go through this from time to time, depending how much you print.
If this doesnt help than you have to probably disassmble the extruder and have a look. there are also guides about it in the links i posted…
good luck, hope youll get it fixed! !!!
Hi Logan,
I’ve had a few problems myself with the same makerbot. I’ve been a proud owner for over a year now so have experienced a lot of the technical issues - warping - nozzle clogging - blown up mother board - filament tangling - nozzle head over heating loose x axis belt - parts sqeeking - the list goes on…
I replaced the bar mount assembly on my makerbot yesterday after ordering the replacement part a month ago. The bar mount assembly is exactly the component your having trouble with (nozzle with kap tape section)… Sounds like you may have some other issues as well but pla leaking sounds to be the most serious.
Anyway is your printer in london? If so I could take a look for you and replace the extruder with my old one. Its still functional just needed to replace for general maintenance
If your quite far away maybe I can just send couple of links that might help
I’m building a 3d printing service at the moment and thought it would be useful to offer printer MOT’s… In this case I wouldn’t charge, more interested in piloting the experience
Cheers!
Elliot
From Microworkshops
The nozzle needs to be butting up against the threaded tube inside the heat block. If they didn’t put the rig together with this in mind, the results would be what you describe. Tear it down and do it right.
Tmallard has it right in the other thread Talk Manufacturing | Hubs
Hi Logan,
yes, the opening of the extruded head (more exactly the closing) has to be done carefully - if it is not correctly sealed, the you will see loss of PLA from above the block - after doing any maintanence here, once you have carefully screwed in the heat break tube above the block, then the nozzle itself just below, but MAKE SURE that there is a tiny bit of thread still visible on the nozzle side when the nozzle won’t go in any further (that means that inside the block the nozzle has met with the heat break tube), and DONT tighten too much whilst cold - once heated up to 200’C then apply the final careful press with the spanner, whilst holding the block with a monkey wrench, to make sure you’ve sealed the block whilst hot - there after you should not have any PLA coming out from above the block!
Whilst your at it, make sure all the othe screws (fan, etc) are also tight - you may have to undo other screws to get to the screws under the fan that attach the fan holder to the main block.
if I’m doubt, check out the makerbot channel on YouTube, I’m sure there is a video explaining all this
cheers!
andy
This is a photo of a Replicator dual (original) not a replicator 2. Did you upload the wrong photo? Rep duals print with ABS not PLA.
So going on the assumption that you linked to the wrong photo. Tighten everything. There is no way that plastic should be able to ooze out anywhere if the extruder is tight.
My Rep1 Dual prints in PLA just fine. The Rep2 can’t print ABS because it lacks a heated build plate. The Rep2X can because of the heated build plate.
I don’t really a dripping of extra material but it looks like there’s some buldge on the bottom horizontal shoulder. Must be an internal leak. I’ve never seen anything like that with ABS on my 2X. When I’m clearing jams in the extruder head I remove the overhead drive motors and manualy push/pull material directly with my hands or a pliers when more traction is needed.
Sorry for the confusion, (I’ll make this noticeable) NOT MY PHOTO. The printers are my school’s and so I cannot go see it again till Monday. I may have a pic or video on my phone that Ill try to upload.
Yeah it might be because the hot end assembly isn’t put together right. Or just not seated right. It’s my least favorite thing about the machine.
Fargo3D
February 21, 2015, 10:07pm
14
It sounds like it might be time to replace the heater block assembly . A fresh thermal barrier tube, heater block, nozzle, and ceramic tape should make it all better.
I don’t know if proper procedures were followed when taking off the nozzle, since at my school I print more than anyone, but they still think taking it apart past the point of the heatshrink is a job for the adults… however when taking it apart and putting it back together I do not know of any specific method or way that the teacher was following. I get the feeling there is some kind of issue or loose bit in there… It seemed like a really rushed job to me, and I already had to tighten other screws.
Hey Logan,
-Maya
The Build Shop
MicroFe
February 21, 2015, 11:27pm
17
If you have had the unit apart one thing worth double checking is that the fan on the front heat sink has not been installed back to front. When its the wrong way around the PLA will overheat above the heater block and become too soft for the feed roller. Eventually (10-15 Minutes into a print) it will stop extruding. There will be a mess around the feed roller that needs to be cleared. Sometimes the PLA can be seen feeding out of the side near the stepper/feed roller area above the heated block.
Fargo3D
February 21, 2015, 11:33pm
18
This. We’ve diagnosed a few “broken” Rep 2’s that just had the fan mounted in the wrong direction.
Yup somebody messed up the head most probably. Have you been running regular maintenance? Do you have the new spring loaded mechanism to push the Filament in the Extruder against the gear to push it out? What’s happening is there is now a gap between the heated Filament and the Nozzle so the Filament bends and extrudes out from another outlet created during the messing about with the head.
3dmasc
February 22, 2015, 4:32pm
20
I use Goof Off heavy duty wipes and AR Kleen Lens cleaner to keep the extruder going once it clogs. Have not had to dissassemble as of yet - and have a standby extruder on hand just in case.
I am located in Chantilly, VA. If not too far from me, I could come by and take a look.
First, it looks like you are working on a 2x. I also dont see anything from the picture.
It does sound like your nozzle is loose. Someone might have stripped out the threads! In that case you might need a new nozzle and aluminum block.
