Jun 2015
I AM HAVING TRUBLE PRINTING WITH RADIO SHACKS FILAMENT ANYONE CAN HELP? A HAVE A PRINTRBOT SIMPLE METAL
    Jun '15
    Jun '15
  • 13
  • 1.5k
  • 10
AND YOU HAVE A BROKEN “CAPS”-BUTTON.
Just kidding :wink:
I would recommend to print with normal PLA settings, temp 210C and speed up to 50mm/s to start, you can later go faster to test the limits. Take the basic retraction settings and 50% cooling, improove upon gaining experience with the material. First print some test parts from thingiverse or similar platforms to test the best bridging settings, overhangs etc.
Marius Breuer
Use a caliper to ensure the diameter is indeed 1.75mm. That has caused issues with other cheapo PLA with my printers before.
What is on the bed? It looks like there is something on the blue tape. With the unheated bed, I found that I needed to use plain white masking tape, instead of blue masking tape. I would get corners peeling up with the blue tape on an unheated bed. Also, try lightly sanding the blue tape.
As mentioned by someone else, the z probe is pretty critical as well. I’ve had to go as far as M212 Z-0.62 before I had the proper depth, but start at M212 Z-0.2 and go down by .02 at at time, so: -0.2, test print; -0.22, test print; -0.24, test print, etc.
