Hey @MattG,
Thanks for your reply. I had this kind of imperfection in two different points of the printer, not on the same level: that’s the reason for which I’m really curious to understand the cause of the problem. Here is the Gcode if you want to take a look. In any case, I’ll check tomorrow but apparently the hotend is moving without any problem and it’s the first time that I have this kind of imperfection.
Fans were running at 100%. I cooled down the temperature manually after the first hour because I noticed that it might be a bit to high.
@federicogiacone
Frankly I sincerely doubt this is a cooling issue. I just doesn’t make sense. Before you risk your health, see my reply below.
There is a whole lot of guessing going on in this thread with very little information to go on. I’d be skeptical of any of these answers so far, even “slow the print down”. That one is used as a cure-all, but it isn’t always the right solution.
20% infill. The filament looks like really fine, so I won’t say that’s the cause of the imperfection.
Thanks, I’ll take a look at this and post some screenshots.
glad to help!
Take all the time that you need, I’m not in a rush. It is just curiosity and willingness to learn
And, if you find out any issue with the Gcode, can I ask to point me where is it? I’m trying to learn how Gcode it’s working and it’s always nice to have see the point of view of someone else
Hi @federico3,
Please check these 4 things:
1. Consistency of the filament diameter
2. Temperature variation; What is the off-set on your hot-end? 230 on your screen could be 215 or 245 etc. in real life with your machine
3. Are you certain that your PTFE is still in good condition (no brown parts when you open the hot-end assembly on the white PTFE part)?
4. How well is your machine performing at this point mechanically? Are all the belts tightened etc?
I’m suspicious of option 1. and 3. but let’s see what you can tell us
Hey Remcokatz,
Now I’m at home and tomorrow I’m not in the office, in any case, I’ll ask someone else to check it.
1&3. The material should be fine: the filament is completely new (I opened the plastic bag just one day ago) and I didn’t have any problems with other prints.
4. Mechanically speaking, the machine is perfect.
3. I’ll try to run again the code and I’ll let you know what was the temperature
Thanks for your help
MattG
19
Alright looking forward to the feedback!
MattG
21
I think it is a problem of temperature.
One of two things.
Perry
MattG
25
In looking at the gcode, I am going to stay with my original analysis.
Hi Perry_1,
Federico
@remcokatz I’ve measured the filament in three random spots, the results are quite regular: 2.90, 2.87, 2.92 mm
MattG
30
