Jul 2017
did you change the system units to match the imported file’s units before exporting?
Hey…just wanted to see if my last message came through.
You’ve been very helpful so far. I hope to continue learning from your tips!
Thank you!
-matt
No didn’t get your first notification. Yes changing those units should export the design correctly. That may be the reason as to why you were not getting a thumbnail when exporting as the design was exported smaller than what it should have been.
Oh, awesome! I think that worked - I had it at mm instead of inches.
Thank you so much for your help! Would it be okay if I got in touch with you again on here in the future? You seem to know your stuff.
Actually, I spoke too soon. Apparently I exported the file as a F3D file, and THAT worked.
But then, when I tried to export as a STEP file, I got the same results - the export completed, but the file was empty when I tried to upload and open it.
Is there something I’m doing wrong? Do I need to change settings somewhere else?
6 months later
1 year later
Hey,
I just found this website here. I tried and it and worked well for me.
They took some days to delivery the file but its ok, its for free anyway.
Hope it can help you …
cadmeshanalytics.com 414
24 days later
11 days later
hi could you write in more detail how to use this please.
In windows command line I should write stltostp <stl_file> <step_file> [ tol ]
can you show the example how to input the file names and what tolerance shall I type in? what are acceptable values?
say in I have file in C:\Users\Tata\Downloads\stl_file.stl
3 months later
