Dec 2017
Something seems off. I’m getting very noticeable filament lines in my prints. Some parts of this model look a lot better than others as you can see. I have tried adjusting my temperature (195 Extruder, 60 Bed), speed, height (0.1), the works. I’m stumped. Has anyone had this issue before? I’m using a Monoprice select mini printer and Hatchbox PLA 1.75 filament. Please help me if you can. I would really appreciate it.
    Dec '17
    Dec '17
  • 7
  • 3.3k
  • 7
That is weird. My first recommendation would be to experiment with your flow rate (I would try increasing it). Increasing the temperature slightly as well (try 210C) might coax the layers to bond better. Also, check that your perimeters are set correctly (2x your nozzle diameter so .8mm in your case) and make sure the infill percentage isn’t too high (try 15% or 20%). Hope that helps!
