Jan 2016
Just got a Prusa I3 (He 3D) reprap printer. This is my first ever 3D printer and the learning curve is great. I’ve got to the stage where I’m printing from sample files (spare parts for the printer). I can load and slice the file and send it to the printer.
It starts printing and seems to be going well but for some reason after a short time, I think normally on the second or third layer, the Extruder always moves off the print (maybe by 4-5 cm) and continues trying to print but off the object it was printing. Obviously because the hotend is now off the hotbed the fililment just comes out and goes anywhere.
Does anybody have an idea if this is a problem with the slicing or some setting in Repetier that is causing this problem? Any help would be greatly appreciated, I’m still trying to figure the whole thing out!
thanks
    Jan '16
    Jan '16
  • 9
  • 1.2k
  • 8
Hello and welcome to the community! I have a prusa myself and I agree the learning curve is steep. My guess is that you’re getting some belt slippage. Make sure you have the x and y belts nice and tight, you can use clothes pin springs or even a 3d printed belt tightened to tighten them up.
Try to check option in firmware called motor timeout (or something like this), motors can be forced to power off since couple of minutes.
