Sep 2016
Hi Doug,
Thats interesting, I found that I had to bump up the bed plate in winter to keep more heat in the enclosure to stop warping. Ok thanks, I will try a few of these suggestions out and get back to you.
Cheers
Andrew
Yes I have to say I am less than impressed with their customer service and given the fact that their printers do not seem to be the best (look at Zortrax way outstripping them on the 3D hubs rankings) I don’t know how they think they are going to compete, maybe just flashy marketing. Anyway nice article Joe, thanks for the share.
Cheers
Andrew
Actually the thermocouples and fan wires were 2 different problems (lucky me!). The faulty fan wires would allow a 10-15min print job but the thermocouples would throw a temp failure. Both thermocouples went out withen a week of each other and I would continue to print because when 1 went out I set the machine as a single extruder (Tool Count = 1) in the sailfish firmware. Trace your fan wires to the plug on the MB and move them around trying to get the fans to stop. If you can get them to stop, you have a problem. I am, of course refering to the MotherBoard fan and NOT the extruder fans (of which I thermal epoxied alum heatsinks w/fan on the back of the extruder stepper motors).
eBay item number:
351047246939
-Bill-
UPDATE
Ok so I stopped directing the lamp into the enclosure and I also took an old bedsheet off the top of the enclosure (which I was using to keep the heat it) and it seems (don’t wana jinx it) to have fixed it. I have run 9 prints with no stopping extruding including two 4 hour and one 13 hour print. Although now there seems to be a tiny bit less adhesion between layers but I will still keep tinkering with the settings.
Thanks to everyone for the advice and suggestions especially to @bumsarama who suggested running without the lamp.
Cheers
Andrew
EDIT
Ok so the first print I ran after this failed after about 30 mins (typical) but this was using the left nozzle (standard makerbot) and all the other prints that worked were using an upgraded nozzle on the right hand side. So I am going to try the right nozzle with the same print and see if it works
I was just having this same “notch” problem with the replicator 2x as well. Glad to see it has already been addressed. Raised the temp to 240 and am going to try it now. Excited and hopeful. Great site here!!
1 year later
Hey Andrew,
I seem to have the same problem .The extruder gear is eating off the filament coz of the continuous tiny movements. And it makes a notch and it is not able to extrude further , usually freezes off after 3 to 4 layers(usually the supports). Did changing the thermal sheet in the extruder work? Or reducing the temperature work? I tried to reduce the velocity of the print to 10mm/sec(from 90mm/sec) to reduce the viscosity. It did not quite work for me. Any suggestions on how to fix this problem ?
Hi Manush,
I found that my fans were installed the wrong way around, they were sucking rather than blowing onto the heatsinks, so I switched these around and also upped the temperature. Upping the temperature seemed to work. I still have the occasional failure but nowhere near as much. Also clean the extruder gear (where it is notching the filament), hopefully this works for you too.
Cheers
Andrew
