May 2015
I designed a 3d model of Roger Ebert dressed as Emperor Palpatine giving two thumbs down for our Oscar Pool Fantasy League trophy.
I’m trying to print the award with Copperfill filament and I’m getting some mediocre results. I’ve had some good results with regular PLA but the Copperfill + “the Ebert” AKA “Darth Criticus” is giving me a real challenge.
Here is a render of what “the Ebert” looks like in Simplify3d followed by a couple photos of what he actually looks like when printed with the following settings:
http://imgur.com/a/jaO4a
3D printer:
Flashforge Creator Pro Extruder
temp: 230
Layer height: .3
Printing speed: 4800 mm/min
Modeal orientation: vertical (like in the render photo)
Bed: blue painters tape + 50 degrees (with no heat the model was detaching about 50% through the print)
Shells: 4 Raft: On (2 layers)
Skirt/Brim: On Generate support: no
If anyone has any advice to help me bring Ebert (back) to life in the way he deserves I’d appreciate it.
Happy to answer any questions, share the model file, etc. if that’s helpful.
    May '15
    May '15
  • 16
  • 1.3k
  • 13
Hi Charcoal86,
Are you sure 230c is neccesary for copperFill?
I have no experience with the Flashforge but the Makerbot is a similar system and it prints the metal-filled materials (bronzeFill, copperFill, etc.) around 195c I believe.
You will definitely need support for this model at the bottom/back of the chair, to prevent the sagging on the 3rd picture
You should contact colorFabb support (support@colorfabb.com) with this question, listing your problems, settings etc. and they should be able to help.
Maybe someone with a similar printer to yours can shed some more light on this as well.
Good luck!
You need support. A lot of support. My advice is that you break this model into as many pieces as you can, and print them separately, then glue them together.
[Vader voice]
find your lack of support disturbing !
[/Vader voice]
BTW, do not throw away your failures, loty of money there, I’d like to test my shredder–>Extruder on them :slight_smile:
The failed print can also be used to test polishing. As long as just steelwool, brushes and sand paper are used, you should be able to still recycle the print. The use of polishing paste etc. may cause trouble in the recycling process. Cheers, Marius
Hey @charcoal86, @Roel might be able to offer you some help - he’s got loads of experience with the special filaments.
