Nov 2015
Hello! So, I am having a little trouble with my CTC 3D printer. I have a lot of questions, so be ready and keep in mind that I’m new, so I don’t know a ton. Also, I want to do this cheaply, if at all possible. :slight_smile:
First of all, I can’t level my print bed. Well, I know how, it’s just that it won’t work. My bed always ends up so that the front of the bed is higher than the back. I have have only had a couple successful prints, but my success to fail ratio is like 1:10. However, usually the extruder stops extruding when it fails soooo yeah… Nonetheless, I know having a level print bed is super important and I want to fix it and the not extruding problem.
Next, I also want to install a glass print bed. My main question is if using a mirror (like in this video) will work. Or, should that be avoided and do I need to go with something else?
Thirdly, I also want to know if there are any mods that are super useful and/or almost needed. For example, supports where needed, or bearings or something like that. I am completely open to suggestions!
4th, getting out of the printer itself, I just want to know what filament to get when I run out of the stuff CTC gave to me with the printer. I know it might sound a little dumb, but I just don’t know what stuff is good and what stuff is bad. I’m thinking about ColorFabb, but, I just don’t know. Also, it needs to be PLA. I like PLA. :stuck_out_tongue:
Now, the final question, getting out of physical stuff, I just don’t think Makerware is cutting it. I want to find a new slicer. Preferably free or VERY low cost. Don’t worry, I already know about Simplify3D, and it’s too much money at the moment, so please don’t say just get Simplify3D.
Holy cow. I am surprised at how short of a time this took me to write. However, thank you for taking the time to read this, and hopefully you’ll help me out, and maybe another lost person on the interwebs, just trying to get there CTC running well.
Finally, the last few sentences. Thank you all for reading this, -saddlepiggy
    Nov '15
    Oct '18
  • 12
  • 4.8k
  • 10
8 days later
3 months later
Are your all metal thermal tubes threaded? If yes, May I ask where you purchased them. Also, if they are threaded, I assume you needed a new cooling bar as well. Did you get the bar from the same place?
I have looked at the one provided by Carl Raffle (https://shop.raffle.ch/), 10 but this is a direct replacement for the existing cooling bar.
Looking forward to your response.
2 years later
I have some PVA filament stuck in the right extruder filament head. Not at the top or the bottom but in the middle, how do I get it out?
