Dec 2016
Hi guys, since several of you contacted me, i wanted to inform you about the status: We decided to purchase an Z18 to make sure we can adapt our 5th gen replicator HBP system for the Z18. We received the Z18 2 days ago and had a lot of work to adjust everything (really unbelievable how some things were mounted at an 8000 USD machine btw) Do not understand me wrong, we do not plan to make the existing build plate fit to the Z18, we are making a special Z18 version, just in the same kind like we did for the Rep 5th Gen. I think there will be no big problems and I guess in a few weeks i can inform you that it is available. :slight_smile:
I cant wait, I have to agree with you the Z18 really lacks in build quality for such an expensive machine, a lot of things happened at makerbot through the production and further development of the z18, many features were cut or posponed and the printer was then finally marketed as a PLA only printer when in actual fact this was suppose to be their flagship printer with multi material support with all the bells and whistles utilising the same patented tech from stratasys, they only went as far as to redevelop the smart extruder + sadly no stratsys engineers were put on the project the team was loosly filled from new and leftover employees from makerbot, the team did a reasonable job all things considered however stratasys probably realised the capabilities of this machine and that it would outperform many of the other very expensive objet and fortus machines if they were to allow it front and center stage time.
3 months later
Any other news on this? @wabasoc did you get a HBP on the z18? I’d love to chat with you if you did so I can add one on mine. @id3d can you provide some more detail on you upgrades? If you are vetted I’d send you my build plate for you to create a HBP for the z18. Thanks everyone
Whats going on with this I am ready to drop some cash for one
Hi guys, i already replied to some of you in a personal message. It took way longer than expected to bring the 5th gen thing on the market, cause we had to do a lot of certification and stuff. I will inform you here as soon as the Z18 Version is available - sorry for the long waiting, i would have liked it faster also :wink:
thanks for the reply, are you able to provide some specs and an inclination of what it will look like, what functionality will it have? is it tied into the firmware? and a rough cost if possible thanks and hope to hear from you soon. i cant wait to start printing abs through the z18.
I’ve done some small tests with ABS and the layers look amazing but need the HBP.
Hi, it’s completely independent from the software and firmware. It has its own controller where you can set the temperature directly. So there are also no changes at the printer needed, you just replace the original build plate with our build plate system and can switch back whenever you want to the original one.
Is there a website I can check out your products? one of your posts said you have a system for the 5G, I would love to get one of those and worry about our Z18 later. Thanks.
3 months later
Hi together, finally the 5th Gen version is ready for sale and online on ebay
I will make our international shop as soon as possible as well, there you can save a few bucks ebay fees :wink:
If you do not want to wait you can just send me an email to info@ide-3d.de, the price will be 449 USD off ebay.
It is the complete ready to use thing, with power supply, controller and build plate. Just to plug in, slide the build plate in and set the temperature.
We will have the same thing online for the Z18 finally online soon as well :slight_smile: I know it took way longer than expected unfortunately but you have to do a lot of things when it is no DIY thing…
The price for the Z-18 Version will be the same.
whats happening with the z18 HBP. Its been 9months. I will start manufacturing my own within a few weeks if i dont hear back
Hi, it is ready, we are just waiting for the product pictures and the CE certificate.
cheers
Karsten
We did not test the absolute maximum but 100 degrees Celsius are no problem. For ABS we recommend 90 - not cause of any limit, but this has the best results.
If you like to tell me wich temp you want to reach, I can do a test and tell you if it works.
cheers
