Jun 2016
Hey guys, I have one of the PowerSpec Ultras (FlashForge Dreamer Clone). It works great for the most part except I’m having repeated issues of the filament melting in the teflon tube before it gets to the extruder, thus making a massive clog. Has anyone else had this issue, and is there a way to upgrade the heat break so it’s more effective? I’ve noticed that the cooling fans barely have any surface area on that heat break… I put some mid-level CPU paste on it (not a lot, just a little) and it’s helped some, but I’m still having issues.
OK, Can we get a few more details? Is this happening when you are trying to load filament, or when you are printing?
If when you are printing, does this happen after the print is going awhile, or right away?
"Replace the Teflon with inserts from micro Swiss " - no, don’t do this, its probably not the answer right now. If you give us a few more details, we can help.
Also, does this happen, then it happens a lot after that? Or is it truly random?
I was looking at those. Logic tells me that replacing a non-conductive material with metal would make it worse, I sent them an email asking about it though.
^^^ Good Answer, I actually just preheat and disengage the tension on the servo, gently push filament (you can feel the feedback on the extrusion), depending on how I left the printer I may feed 2 inches in before switching to the next. I should clean way more often :slight_smile:
