+1
I’ve had pretty poor luck with most general purpose glues, but a few months back I was able to obtain several 3DSystems “CubeStick” sticks. It’s worked amazingly, sticking well to every type of plastic I throw at it and washing off easily with water.
The only problem is, I’m running out and might not be able to obtain them from my original source anymore, and buying them is far too expensive. Anyone know what exactly it is and whether or not it’s available in some other form?
Hi, the solution i found i think is the most economical, and easy to find in the stores, but it works 100% for my PLA, ABS and laywood prints.
I cover my bed with the yellow paper tape, that is normally used by painters.
I heat the bed at the desired temperature and about 1 minute before the print starts I apply on the paper tape some stick glue, normally used in the schools by kids to attach papers, the most known brand here in Italy is “Pritt” or “UHU stic”
Newer had problems anymore.
Thanks a lot!
does it work for large parts?
3D systems cubestick is fine and I have used it successfully in the past for ABS; the only downside is that the price is steadily rising due to its popularity and then its not widely available. Time to try Elmers washable glue I think.
Just a note to say I tried a new method to adhere parts to bed. I use vinyl application tape and use squege to apply a light coat of super glue to the tape after installed on the bed. Let it dry first before using. It works better than anything I have ever seen and last a long time too. first one is hardest to remove but its not bad and don’t tear the tape. thought some of you might like to know this trick works and cheap too.
Great tip. I had no luck with the glue stick method, and was about to look up which kind of hairspray to buy, when I came across this post, and I figured I might as well try it before I went shopping, since I had a liter of wood glue sitting on the shelf.
I was sceptical before starting the first print, as it didn’t really look like I had done anything after applying the wood glue mix, it just looked like the glass was slightly dirty. But the first try went better than the most of my attempts with the glue stick, which I had been struggling with for a couple of days. It’s not quite perfect, but I did mix it with water, and made a very thin batch, so I will experiments with applying several layers and adjusting the mix to make it a bit thicker.
Thanks, i will try this, all other (conventional) ways seem to fail for me…even with PLA.
The one i have had best success with is 50/50 water/sugar brushed on to the plate.
@Thomas1, sugar ftw
I know this an old thread but I wanted to share this awesome spray I found, it’s almost too good to be true.
My girlfriend is one of those makeup hobbyist types, seems to be all she does. Anyways, when she was getting into Wigs and styling them, she bought this spray off Amazon. It is a little pricey but man, this stuff is like spray glue! In fact this is what it is, it is spray Wig/wig cap glue NOT Hair Spray. This stuff is easy 5x thicker than hair spray
I do 1 light sprayed layer from top to bottom and I have a very thick layer. In fact this stuff, I noticed I sprayed on my test just a small space a little bigger than my test print. When I went to do a larger print, I thought, let me clean this up so I can do more. Damn stuff took a Rag soaked with Alcohol and about 10 passes to get it all off.
I am serious when I say Glue Stick in a Can.
It might seem a little pricey but honestly, I used under 1/4 of what I would use in hair spray! I seriously did only 1 pass.
As a test, I did a single very quick layer while the printer was fully heated. The print bed, was just a hair off (on purpose) to where 1 corner would not stick and drag on a brim. I did a quick layer spray, watched it dry on the glass (20 seconds) and hit print. This print mind you failed on the Brim consistently 4 times in a row (did this on purpose though) with the rear right corner not sticking. With only a 45 second dry, I printed my test part and brim, instantly perfect results! My jaw dropped so fast that all I could think was- Why haven’t I heard of this stuff in a forum?
This stuff is called:
Brand: Schwarzkopf
Line: got2b
item: glued blasting FREEZE SPRAY
here is the Amazon link-- Try this out-- I get nothing for this BTW, I just was THAT IMPRESSED and I am a newby.
https://www.amazon.com/Got2b-Glued-Blasting-Freeze-Hairspray/dp/B01MD28T59/ref=sr_1_1_sspa?crid=11APUJXWIJZJ1&keywords=got2b+glued&qid=1561045083&s=gateway&sprefix=got2%2Caps%2C259&sr=8-1-spons&psc=1
I have gotten really lucky, 1 month in Did a RAMPS conversion with 0 issue except I broke my heater cartridge ends off while doing my MicroSwiss All Metal Hot End. I love the forums and wanted to do my part to add to the community
