Oct 2016
Hi, recently got a flsun kossel and apart from a couple issues it’s. Working perfectly. One of those issues is the top and bottom layers don’t seem to be joined together properly (spaces between the lines). The bottom layer is the main issues, but the top has issues as well. If anyone has some suggestions that would be great. If you need any details about settings let me know. Thanks
    Oct '16
    Oct '16
  • 14
  • 6.3k
  • 3
Ideas:
1 your extruder gear is not gripping the filament properly, clean the gear and make sure the bearing has higher pressure on the filament
2 the filament diameter is varying to much, measure it
3 the extruder motor is skipping steps
4 calibrate your extruder again to see if you extrude 100mm it is really extrudes that much
Check these and see if its helps.
Thanks for that, will try it when I get home. Thinking the bearing might not be tight enough. How would you measure how much has been extruded? Do I put a mark on the filament 100mm from the extruder entry and make sure they match in the end?
Here’s where I got it from. https://www.3dprintersbay.com/flsun-autolevelling-kossel-diy-kit 10
Got the speed issue sorted, it was using the manual adjustment speed not the travel speed in the startup gCode. Forgot to export the settings, but will do that this afternoon.
Think the only issues I got now:
  • The first 2 layers seem to thin out to nothing at points on the bed. Think it’s from the bed not being 100% level once it’s got the masking tape on it, but not sure if it’s just crap tape or a bigger problem
  • When I print a raft (to fix the above issue), it prints in a way that’s impossible to remove
Again, thanks for all the help :slight_smile:
