Aug 2015
At this point they are all beta. I found the latest one from their drop box work best
hello, i also sometimes have this problem. just use a small spatula or a common scalpel/blade and pry off your model from the printer bed. i now use blue tape and the model comes easier.
it should not be a problem, just use the spatula and use it as a lever on a model section. start from there and keep prying off moving on the perimeter of the model to loose it from the printer bed.
hope it helps …
Try prying it off with a card if not try a wallpaper scrapper. And if you have a removable bed then put it in a freezer. Hope this helps
My point was that at one point there’s a version that makes everything stick like crazy. So it worked a little too well. Raft is unseperable from both model and buildtak… So newer version works better
For some stubborn prints, take the build plate off and put it in the freezer for 10 to 15 minutes and then try prying. Careful, I have gouged the buildtak on my M3D printer just prying. I do agree with you that the newest software does make the part really stick.
Compressed air in the can usually works the best for when this happens to us. Hold the can upside down and give it some good sprays around the edges. This causes a change in thermal equilibrium and the plastic will contract from the glass surface.
