Sep 2017
Five months back I had bought a Monoprice 3D printer. Amazon.com I had printed with it two of the test print cats that came on the memory card. When I went to print a model for a friend (my third printing) it had caused the nozzle and heating element to become entangled with the fibers and encased in plastic. I have since cleaned up the nozzle and cleared off all the plastic (thank you to all whom made suggestions on how to do this). My problem now is that when ever I try and print something, the plastic doesn’t stick to the heating pad and just gets swirled around the nozzle. I have to stop the printing and clean it off each time. Any thoughts as to what might be causing this and how to stop that from happening? Any suggestions would be appreciated.
    Sep '17
    Sep '17
  • 5
  • 1.4k
  • 3
Well I tried wiping down the pad with the rubbing alcohol and nothing changed, but I DID notice something during that test print. The filiment seems to curl back upon itself as it starts to print. The printerhead slowly moved down to the pad so I use a pair of pliers to pull off the excess in hopes that would solve my problem. Sadly, it didn’t. So I remove the nozzle and let it soak overnight in the rubbing alcohol. Will take it out today and let it throughall dry. Also, I will pull out the entire length of filiment and put it back in like the instructions said when I first got the machine. Hopefully this will work. Thanks again for all the suggestions! Wacky
