Oct 2015
Does anyone have some good tips for ABS warping during prints on the FF Creator Pro? I have tried a ton of different combination of settings (Currently using Simplify 3D), glass plate, hairspray, kapton etc… My prints are sticking great! And the build plate is level (PLA prints perfect). But I cant get the warping on my ABS prints dialed in. Any help is appreciated.
    Oct '15
    Oct '15
  • 16
  • 3.5k
  • 11
You may be fine since its not certain what temperature the end of the PTFE tube is getting nor what the actual temperature limit of that tube is really. But I thought I’d pass along the info since we’re getting up into the limits for this machine at > 240. I’ve recently bought an all metal nozzle and tube from Micro-Swiss that I haven’t put in yet that should remove at least this limitation. My goal though is just to see if I can get it to extrude PLA faster and smoother so I can crank up the speed without losing so much quality.
Try Buildtak. My Creator Pro came with something similar to it already installed. ABS sticks to it as well as anything else you can find, and there is no mess as with glue-stick, hairspray, etc.
Different brands of ABS will be more prone to warping than others, but ABS curling on long and thick parts is simply a reality that you’ll have to learn how to work around. In many cases you can redesign the part to minimize or eliminate the problem. Using a brim also helps. (Yes Simplify 3D has a brim - In the Additions tab, check the box “Use Skirt/Brim”. Set the Skirt offset from part to 0.0mm, and set the number of outlines)
When all else fails, just print with PLA! I’ve printed huge, blocky PLA parts on my Creator pro which almost filled the printbed in both directions and were over 4 inches thick. They took a whole pound of PLA to print (26 hours) and were a bear to get off the printbed - but NO Warping!
Does anyone know what the ideal ambient temperature for printing ABS is? I am considering installing an enclosure heater with a circulating fan similar to a convection oven to stabilize the temp. I’m not sure what specs on the heater I need will be though. - Thanks - Phil
13 days later
Ideal temperature is 80c, BUT at that temperature you may be risking damaging/shortening the life of your steppers. With just the bed as a heat source you can only get internal temps up to around 50C, so anything above that would help.
