Try lubricating your filament. Do one drop of canola oil on the end of your filament then feed it in. Also you can take a paper towel and a binder clip to make an oiler that lubes the filament before it enters your ptfe tubing. I find that especially with PLA, this really helps on both my direct drive and Bowden printers.
How would I go about changing this? I have tried to adjust the current, but it didn’t seem to do anything. I just need a bit more detail, this is my first printer I have owned.
There’s rarely an issue with the stepper motors. I’ve had feeding trouble, also, and it’s always been a mechanical issue such as the tension spring had too much or too little tension.
One other factor you may not be thinking about is thermal issues. If the ambient temperature in your printing area is too cold, you will have trouble with feeding.
Can you respond with specific details about what you’re seeing? For instance, when you preheat the hotend, then extrude do you see the hob rotate and chew up the filament? Does the hob NOT move? I think if you can paint a clearer picture for us we could help more.
The stepper motor does not run smoothly, it will rotate on its own when it is not installed, but it has a very jerky motion. It’s a new motor, and the old motor does the same thing when connected to that cable.
The filament does not get chewed up and the and there hasn’t been anything wrong with the temperatures. (I installed my hot end on another printer, and it worked fine) The motor doesn’t seem to have enough strength to push the filament through, it is unable to strip the plastic off the filament. It twitches back and forth when it hits any resistance. The hot end is also completely clear of all plastic debris.
If the same behavior is occurring with different motors, then the issue is likely not the motors. It could be a physical issue with your controller board such as power delivery or firmware. Also, wiring is always a possibility. “Jerky” sounds like a bad connection, so that may be a good place to start.
It is a modified Prusa i3 printer, the whole extruder assembly is completely clean and free of debris. The two wheels are under the correct tension. The plastic does have the small dimples. When the filament does not extrude, it is not being stripped either, the motor simply twitches back and forth, like it’s too weak to do the job.
Thanks for the reply, I’ve ordered new wiring. I’m not sure it’s the control board, because every other motor works perfectly, and it’s a new board that I had replaced rather recently.
When the motor is not installed, I can easily push the filament through. Even when the motor is installed, if I help push the filament, the motor will extrude it, on its own it is unable to.
