I’m working on a project that requires a high volume of non-complex pieces that average 25 cm3 material volume a piece. I need to print 400 of these pieces. Having looked around at numerous services it’s become clear that the price to print using a service would be close to the price of an entry-level printer. I am familiar with 3D design and have had objects printed before, this is the largest project to date and the reason I’m running into this question now. Would it be more economical to buy a printer to produce these pieces and at what speed would I be able to expect a print? I have attached the stl file. Any help or suggestions would be greatly appreciated. pentagon3.curve_.stl 2 (87.3 KB)
I guess you’d expect the answer to be “Well, it depends…” but I’m afraid it does!
It depends which printer you’re using, how fast it’ll print ( of course! ) :-), the degree of in-fill you need ( if it’s solid, hollow or has some pattern of material inside the surface “skin”, to some extent, whether you’re printing raft-less, and how many items you can fit on the build plate for one print.
My printer is by no means the fastest or the biggest. I managed to fit 4 of your thingies on my build plate and at 75% in-fill, it tells me it would take 7 1/2 hours to print. At a lower in-fill, we’re talking 5 hours and at zero infill ( just the outside shell, but as thick as possible {approx 2mm} ) it would be 2 hours.
Just took a look with Cura and Netfabb, both of which tell me your widget is about 3mm long and 1.3mm wide. My software tells me it’s about 80mm x 30mm so there’s some discrepancy there. Could you tell us the intended size??
Gawd! Wish I hadn’t started this now. That’s the last time I think “I’ll just answer this post before I go to bed.”!
Finally managed to fit no less than 14 of your items onto my plate and with my quick and dirtiest settings it’ll chug 'em out in 3 hours 18 minutes! Worth just noting that shell setting is more useful than you’d think because you can fill the hollow print with epoxy if you’re after something really solid. Worth thinking about!
Just goes to show it’s worth thinking a little!
Hold on! Now it’s saying all 400 in 35 seconds! No? OK! My mistake!
if time is not important, and you’ve got some experience in 3D Printing, then buying an entry level 3D Printer could be an option. If you need the prints on a somewhat short notice, then I can help you out with selecting some printers in your area. You can contact me on luuk@3dhubs.com if you want to.
Hi Phil
my makerware with infill to 50% and 7 parts for printing cycle tells me 7 hours and 50 minutes and 110 grams of material. Do your calculations of total production.
With infill to 25% obviously doubles the production rate is halved and the weight of material used.
Good job !!
Alberto
ADL’s Power Hub
Milan
By calculating the dimensions of the piece can make us feel 27 pieces on the floor of the press with the right spaces, positioned vertically as you say, but with the base largha on the floor so I do not create any support material and wasting time and remain lower avoiding vibrations .
How material are about 325gr, as time is about 23 hours of printing with infill to 25% and from 0.2 mm layer.
If the piece does not have to have structural characteristics but only aesthetic you could make an infill to 15% and reduces all parameters of development and production.
Sorry I did not want the bother anyone, however, since the question was public anyone can say what they please without limits.
As you can see I have only written a few examples of how to print the project according to the original question, I do not want to steal the job to anyone, everyone has their own experience and puts it in the service of others, I have no economic interest, it is understood by my actions indicative only.
It does not seem a discussion with “exclusive” to someone.
Hello, good job!
Alberto
ADL’s Power Hub
Milan
