Aug 2015
Zortrax also have a ball spindle. The Stratasys Mojo is a FDM machine. It’s good to hear that you don’t have problems with the Leapfrog.
as others said. It depends on products you want to build.
In general SLAs comparing to FDMs:
-more expensive material
-smaller material selection
-very few non brittle materials
-smaller build area
-parts exposed to the direct sunlight should be protected with paint or similar(for use indoor on indirect sunlight there will be no major problem with material degradation)
BUT,
-precision and surface smoothness is superior
-smaller deformation/schrinkage
Anyway if your budget is up to 10k just go for two machines:
FORM1+ and Ultimaker II (larger version)
That way you are gona cover all your needs in beginning.
Cheers
The form1+ should definitely be chosen. I would consider the Lulzbot mini, leapfrog Creatr HS and the BigBox (coming spring 2016) as alternatives to the UM 2 extended. Especially the Lulzbot mini is easy to use and has some nice features (automated nozzle cleaning and bed tilt compensation), that other printers miss out. The Lulzbot can also print with the widest range of materials. The Creatr HS features dual extrusion and is capable of fast printing speeds and VERY large objects. The BigBox combines the Lulzbot and leapfrog creatr HS in most specifications. The BigBox has the biggest buildvolume of all listed printers and comes with a lot of features as standard or upgradable later on.
Hey Brian,
Were are you located I would be more then happy to send you some print sample from the form 1+. Zortrax, Mojo and Pegasus
Hi Brian,
I’m very happy with the Leapfrog Xeed. This is a nice printer between the standard FDM desktop models and the high end industrial printers. I personally think is perfect for engineers.
For its kind it is accurate and fast and relatively cheap. I have looked for high end industrial printers but prices up to 20.000 euro plus are way to expansive for me. It uses a open source system which is great for cartridges and has a resolution of 10-20 micron.
Cheers Vincent!
I have a hobby level printer (a Type Series-A that a buddy of mine built for me - he calls it the Super CupCake - since the electronics he pulled from my older dead MBI CupCake) - and I have a Mojo. I use the Mojo for printing client jobs. Some of my clients have raved that the printed pieces look professionally manufactured - so, that output from the Mojo is hard to beat. I’ve actually produced pieces with small delicate hinges - which work perfectly functional after removal from the Bath system!
Kurt
