Oct 2015
The dual head of Zmorph is pretty hard to use. First you need to check if the nozzles are leveled (as accurate as you can get). You cannot adjust the filament tensioner on both side only together so try to find the best pressure. Calibrate the whole machine, this is very important.
The PVA needs to be dry.
Print at a low speed and it can help if you use a ooze shield. I don’t know if voxelizer has this option so you can use Cura, Slic3r or Simplify3D.
You can also try to print with HIPS+ABS. You can dissolve the HIPS with Limoneen.
