You’re right, the board has a second input for a thermo. But the socket is missing. To test it I would have to solder a JST PH socket to the board which would be an ok task for me. But I am sceptical because I assume it would also need firmware modifications which I’m not capapble of and the dremel printer is not so much open sourced as far as I know. In short I think the printer would not know by itself that it now should use mainboard connector T2 to measure hot end temperature.
The thermocouple has like 3 ohm resistance by the way. so basically continuity.
Skip to main content
