May 2016
I run 2-3 zortrax m200s for our prototyping business and don’t notice the smell. I think that the Z-abs smells less than other abs for what it’s worth.
If you’re in the us and want a great warranty, check out www.protoripe3d.com 3
Hi Jason,
I own a Zortrax M200 and it has been running in my living room for the past few months. I do notice a smell in the morning when I let it run overnight with the windows closed. The smell is not that bad, but I still open the windows anyways and let some fresh air in.
Zortrax is the best of its class while printing ABS, the quality is really the best (for most geometries… no printer is perfect). But of course you are limited to their filaments… Unlike the Ultimaker 2+ which allows you to vary its temperature and feed settings. I still haven’t seen parts printed on the Ultimaker with 20 micron settings, perhaps they have improved with time. Zortrax’s highest resolution is 90 microns, which is already very impressive.
You could of course buy the Z-Temp “hack” for your Zortrax, but it requires a little tinkering. Would suggest you to do more research if you haven’t had much experience in FDM 3D printing.
There are pros and cons for both… I would buy both if I could lol.
Right now I am printing in my M200 and the smell of the Zultrat material is nearly imperceptive. Just if put your nose close to the top part of the printer notice something. Obviously is not despicable a little air flow in the room, also in a small ones. Is not a good idea to maintain the abs smell trapped in the place.
BTW the quality is excellent vs the price; have low maintenance; low setting up to print and no interruptions in large prints, believe me. Probably the bad think is that the materials need to be only of zortrax brand to keep the promise of warranty and quality. Hope this could be helpful.
Regards!!!
Thanks everyone, I am really torn between the Zortrax and ultimaker 2+, I am inexperienced and the Zortrax looks like it will get the job done with excellent quality without much tinkering… but I am dazzled by the exotic filament options on the ultimaker! I think maybe get a Zortrax and then go for an ultimaker down the line. I do hear Zortrax would be eventually upgrading their system to allow exotics anyway. Appreciate every ones input
My experience with the Zortrax M200 so far is that it just works, and it works great. Simple as that.
Regarding smell, you should always use it in a well ventilated area due to the gasses and particles.
I have also printed with Formfutura Premium ABS on the printer with great results. I then used the Z-ultrat profile. The smell of the Formfutura is worse than Z-ABS and Z-ULTRAT.
Regards Torgeir
7 months later
