Dec 2015
I did what you said with the serial ports and Baudrate and installed the GPX plugin from the settings menu but when i click the connect button the Machine State says Error: Connection error, see Terminal tab. and the Terminal tab says:
Unexpected error while connecting to serial port: /dev/ttyACM0 IOError: ‘[Errno 2] No such file or directory: ‘/home/pi/.octoprint/data/GPX/gpx.ini’’ @ comm.py:_openSerial:1312 (hook GPX)
Changing monitoring state from ‘Offline’ to ‘Error: Connection error, see Terminal tab’
Unexpected error while connecting to serial port: /dev/ttyACM0 IOError: ‘[Errno 2] No such file or directory: ‘/home/pi/.octoprint/data/GPX/gpx.ini’’ @ comm.py:_openSerial:1312 (hook GPX)What do i do?
10 months later
What did you do to get your printer working with cura? I prefer cura to makerbot but I can’t get it working, even after running it through gpx.
