I print on a piece of glass with Aquanet hairspray (unscented). One quick even spray and even without the HBP on it will only come off by pulling very hard and throwing it in the freezer for half a minute helps loosen it. If I use more than one coat (spray, wait 30 seconds, spray again) it’s not coming off unless I throw it in the freezer for five minutes. Especially it I heated the bed, then it’s never coming off lol. Integrating only sounds daunting because you have to solder the mosfet to the empty slot, but it’s actually easier than I expected and was one of the quicker mods to do.
I’ve been thinking about adding LED’s somewhere on the extruder so that I can charge glow in the dark prints while they print.
After just printing Marvin, I had to increase the filament diameter to 1.80 in order to increase the quality, even though my glowfill diameter is only 1.74. I was severely overextruding. Here is is. I’m using an active cooling fan, and I still need a bit more cooling. This one was printed by himself.
Why are you using replicatorG??? When I first started I also used it and people would ask me why I’m using repG.
