Jul 2015
The looks of the photo indicate to hot of a nozzle temperature. A very glossy finish is the clue, while a cooler temperature will produce a matte like luster. Are you printing with a third filament cooling fan? Also, I printed my Marvin at 20mm/sec, if I remember. Low slow and plenty of cooling of using pla, same with abs but omit cooling fan until the key chain ring.
Also, you should be using sailfish 7.7. All other firmware has been abandoned long long long ago
Are you printing with PLA or ABS? You are correct the print should not just fail at the end. When I have trouble like this on smaller details I tell my print job at to slow down at the layer I’m having issues with. What you could try to do is print at your highest resolution and look for a setting to change the # of mm/s print speed. That’s my only suggestion at this point.
I’ve done several printer upgrades after getting the CTC. It now prints very well with not too many hiccups any longer.
I’ve been trying to get Sailfish for a couple of days, when I try and change the update URL in replocatorg I just get a network not available message. Any tips?
You are using the wrong version of repG. I think the correct version is r30. Get the newest from thingiverse.
Done! Thanks for the advice, first sailfish print underway now!
What temp did you use and do you have an internal screw type thermocouple or external tap style? Looks like some kind of replicator type machine in the background. That marvin actually looks really really hot, you should use the lowest temp you can get away with. Marius is right, you should print multiple marvins or even put a simple tower next to whatever you print so that marvin gets time to cool. I’m not sure if speeding up the print would improve your results, I think you’d actually want to decrease the speed or increase the minimum layer duration so that the layers have time to cool. I think that plus printing multiple marvins or other objects at the same time and using a cooling fan will improve your results dramatically. If you don’t have a cooling fan just point a regular household fan at it for now.
Also, when you get a fan, something like this Active Cooling Fan Duct for Replicator 1 / Duplicator 4 / FlashForge by thruit00 - Thingiverse won’t make that big of a difference if any because all that ducting lowers the airflow way too much, as axial fans are not made for ducting. Soon as you add ducting, especially tiny thin ducting you lose all the horsepower so to speak. An axial fan would work way better with a high flow duct such as Cooling fan hanger for FlashForge Creator 3D printer by Harh - Thingiverse. A centrifugal (also called squirrel cage) fan works dramatically better than an axial fan. I’m going to upgrade mine to a centrifugal fan soon.
I remember I used to have horrible failures that looked just like your marvin before I made numerous upgrades, and now I can’t fail a print like that if I tried.
Cooling issue, garanteed. I have one of these printers as well, got some tips at the forum, running stock firmware still - my best marvin yet has been produced using a fan blowing directly at it, at around 94% of printing (when the ring is about to be done). I’ll get back to you on my settings for this particular print, meanwhile I’m also working on a simple guide for adding led strips and fans to the case, should it interest everyone else.
Why are you using replicatorG??? When I first started I also used it and people would ask me why I’m using repG.
