hello! Is there anyone that maybe could help me understand the calculations of the delta type printer?
Ive seen that there are different types of delta printers?
Rostock?
Kossel?
(Pros & Cons?)
(I want to build the type using smooth rod and gt2 belts) 500mm~ build height and 250mm Diameter heatbed “round/square” and carbon fiber 8-10mm rods as arms (with M8 uniballs)
I can’t find any good information, that explains all the angles, length of rods and tower spacings and so on!
If I knew then it would be easy to design it in auto desk inventor. I’m stuck guys and really need your help!
Is this your first printer? Is this your first scratch build?
Just for knowledge and moving forward…
Know that there is NO THEORETICAL DIFFERENCE in how any of the deltas operate. They all perform the SAME way, based on the SAME calculations. The difference, is simply the hardware delivery. Either it’s using smooth rods, or linear rails, or some variation thereof. The critical (calculating) areas of ANY delta, are based around it’s smooth rod offset, length of its arms, and the offset of the carriages for starters. Honestly, if this is your first scratch build, I wouldn’t recommend reinventing the wheel on your first try. Not saying that you aren’t capable, but the delta platform is rare amongst makers for a reason… it’s very difficult to master. You could read all you want online, but experience will be your BEST teacher. You may want to consider using a prexisting design, then scaling up, once you’ve mastered that.
Yes I understand that. I am capable of making one that’s for sure. I like the challenge to build stuff
i already have one homemade 3D printer (pursa type) and it’s a pretty simple and easy design.
The reason why I want to build my own delta is because I’m curious. And already have a pile of motors, controller boards on hand.
Feels like it’s a big waste of money to buy a Kossel for $200-1000 to just learn and understand the physics of the delta type. And there is even more money into it if I buy a printer that’s suits my needs?
It seems like there are more people intested in building their own delta to?
Thats why I’m starting this thread about it,
So that other people also can get their hands dirty
