Nov 2015
Hello everyone
a couple of days ago i started to have a problem with my davinci 1.0A when printing PLA (havent tested it with ABS). it will start extruding but it will do a strip of 5cm and then for 1 cm nothing. the strips will become shorter and shorter until it wont extrude anymore its stuck. also it is making a clicking noise. so when i open the extruder the PLA what was supposed to go into the nozzle was to thick. so i started searching online and they said recalibrate the bed so i did this 3 times no luck. another guy said that the temperature was to low but i am printing 200C and also tried 195C and 205C. in the attachment you can see how te end of the PLA looks like when i open the extruder and pull the PLA wire out of the nozzle (it is 33% larger than it is suppose to be compared to the rest of the PLA wire what is 1.75mm). also there is a picture what will show the strips of 5cm.
I have also noticed that a little flexible cap on the hotend where the tempeture sensor is located had fallen off. I dont know of this will show a false tempeture reading and will make the extruder to hot or to cold.
what is really strange about this all is that i printed PLA before with the same settings and same color just fine.
so here are the details
  • Davinci 1.0A
  • Repetier host 0.92
  • temperature 200C
  • Bed temperature 60C
  • bed hight calibrated with a sheet of paper.
  • PLA from 123-3d.nl apollo home brand.
  • extra strong hairspray as sticking material.
  • cleaning nozzle and bed every 3 prints.
  • 2 days and 8:52 hours and 293.3m printed in its life.
  • wire supposed to be 1.75mm when pulled out of nozzle something like 2.3/2.4mm
Greetings Sieuwe
Hey I just wanted you to know I read your message. I know some people had a lot of issues with pla and use some sort of lubricant so it extrudes a bit nicer. I’ve personally only printed abs myself. Would you be able to put a picture up of what exactly you mean?
The clicking you are hearing is the extruder feed gears slipping on the filament and they’re scooping out a chunk of your filament. Two things cause this for me:
1) remove your extruder and clean 25 the “gears” that feed the filament.
2) check your bed height. I have had exactly this happen in both PLA and ABS when my bed height was too close to the extruder. It just requires too much force to feed the filament, and it slips.
Once it does it enough, #1 becomes almost mandatory because the filament particles get shaved off and embed in the feeder teeth. This limits the extruders ability to “grip” the filament and it gets worse and worse.
Mineral oil is the “lubricant” mentioned by Brandon. You can print a “filter” 22
One or both of the above should get you going again.
Please follow-up with the results.
Thanks,
Steve
Hello steve
i have already checked the bed hight with a peace of paper but i will clean the gears and try to lubricate them like you said tonight.
Tanks for you post
greetings sieuwe
Hello
after changing the bedheight again and buying a diffrent haispray brand it works. Everything works as new so thank you all for helping.
greetings sieuwe
Very good to hear. Da Vinci bed height issue strikes again. Mine has the unfortunate feature of an incorrect offset between the metal contact points and the glass. Calibration gets the bed level, but the height is WAY off.
I’ve given up on the calibration routine. I just use the paper method. Works pretty well.
Happy printing.
Steve
