Jan 2017
Good Day, I am really in need of some help, I have built my DIY 3D printer / cnc machine and currently running marlin firmware on the arduino mega with ramps 1.4. I got the firmware for a prusa i3 but here comes the problem, my x,y axis travel is not the same as the prusa’s. So I need help to custom configure the firmware for my machines limits and travel. I will like if someone can phisically help me to tweek my software and hardware to get the best end result. I am based in SA Johannesburg and is willing to pack all my stuff in my boot and come to you to set things up.
Please help!
Regards Johan
    Jan '17
    Jan '17
  • 18
  • 17.6k
  • 9
Im in omaha ne… did you go into the firmware and set travel distance as well as your per mm settings?
Usually I’d offer to customise and send the firmware via google drive but really, it’s not difficult to set up Marlin. And figuring it out yourself with the aid of the excellent documentation both online and in the Marlin file itself will help you a lot in the long term!
Just open configuration.h of your marlin firmware and find/change the
// Travel limits after homing (units are in mm)
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS ???
#define Y_MAX_POS ???
#define Z_MAX_POS ???
In Configuration.h file, you’ll find #define statements for travel limits, end switches direction, polarity and presence, and so on. The comments there are pretty good documentation.
Thanks all for the comments, it seem like with me fiddling around in the firmware and the current weather, my machine changed his mood. Im now printing in the center, with a little fine tunning, I will master the art of 3d printing lol. Ill come and show off my machine an finished work piece once done.
Thanks Again
Regards Johan
