Jul 2016
I am using a Flashforge Creator Pro with Simplify 3D software…
When I print a rectangular object, the edges begin to curl upwards. I am using default settings in Simplify 3D. What settings should I adjust to cure this problem? It seems to be more evident with the left extruder (the one closest to the fan that cools the filament) so im thinking its a cooling issue.
    Jul '16
    Jul '16
  • 13
  • 11.0k
  • 9
I’ve had awesome results with:
bed 90°, kapton tape with acetone slurry and no cooling. ABS is a little bit tricky. Different colors and different spools are having different setups. Usually I’m using 235°-240° as printing temp. I hope this helps
