I’ll bet it came with a roll of abs. Pla smells sweet. Your print looks like abs. Heat bed temp should be 110. I know the rolls are not marked and can come with abs or pla
ABS will dissolve in acetone, PLA will not. I have not heard any one else report mislabeled filament from CTC. Again from those pictures, this is clearly a user error issue, OP needs to learn how to calibrate the slicer. Follow the instructions laid out in sailfish manual.
Hello…
It PLA ive tested with Acetone and dident dissolve… Here is a new print… temp used 240 heat bed 55 using makerware 2.4 i had to sand some excessive material in some places to look like this.
In the picture showing the first layer, it looks like you’re not trammed proper. It’s very squished in the corner and then the stands are not touching further on the solid layer. What do your calibration cubes look like. I also see over extrusion. What is your filament measuring to actually?
You need to download a file on 3d warehouse so you can convert files to an .stl then go onto you SD card and save it but change the .stl to .x3g and it should pick it up.
I’m using a ctc dual extruder and I can not print below 215c on pla. If I go below 215c it clumps up and gets a gritty look n feel to it and many many holes. I upgraded to sailfish 7.7 or 7.6 I forget. I’m using makerbot slicer. Hot end 220 Speed 60 Layer .02 Plat temp 90 Shell 3 Filament diameter 1.76 Retract distance 1.3 Retract speed .25mms Why can I not print pla under 215c I have a ptfe tube in it.
