I’ll bet it came with a roll of abs. Pla smells sweet. Your print looks like abs. Heat bed temp should be 110. I know the rolls are not marked and can come with abs or pla
ABS will dissolve in acetone, PLA will not. I have not heard any one else report mislabeled filament from CTC. Again from those pictures, this is clearly a user error issue, OP needs to learn how to calibrate the slicer. Follow the instructions laid out in sailfish manual.
Hello…
It PLA ive tested with Acetone and dident dissolve… Here is a new print… temp used 240 heat bed 55 using makerware 2.4 i had to sand some excessive material in some places to look like this.
Adam what magic did you do? The file that you sent me… printed very good… it dent finish because it got loose from bed… but what ive seen… its very good… The first thing ive seen that was different was the speed print…see photos…
How did you get your printer to print my one wont read the files on my SD card have used different sizes and used fat16 all that even different file types and names. Also how did you get your printer to work fine on your PC as mine disconnects my mouse and keyboard when plugged in and doesnt detect in device manager. Any help would be great as im new to this as well.
You need to download a file on 3d warehouse so you can convert files to an .stl then go onto you SD card and save it but change the .stl to .x3g and it should pick it up.
I’m using a ctc dual extruder and I can not print below 215c on pla. If I go below 215c it clumps up and gets a gritty look n feel to it and many many holes. I upgraded to sailfish 7.7 or 7.6 I forget. I’m using makerbot slicer. Hot end 220 Speed 60 Layer .02 Plat temp 90 Shell 3 Filament diameter 1.76 Retract distance 1.3 Retract speed .25mms Why can I not print pla under 215c I have a ptfe tube in it.
