Feb 2017
Sorry cannot help with uploading the firmware as I had someone else do mine for me
No problem was not even sure you can go back to original firmware. Maybe someone else could help.
Thanks for your input anyway good to see people having an interest.
Can you measure the voltage at TP27 when the HBP is at room temperature? that’s a tiny copper spot just next to R65, which is next to where the HBP plugs in to mightboard. Put the other end of your meter on one of the ground pads on the ATMEGA 1280 IO just below that.
Hi Jon,
Thank you for youre instructions here are the results. Now to make sure im telling you the right information Ive included photos as Im not an electronic`s wiz as you know by now!!!
I have access to a meter but, only use it for continuity testing so that said details are as follows:
Room temp:- 77.5F
Meter set at 20v DC. Reading taken at points TP27 as you`re photo to ground on ATMEGA 1280 this gives a reading of: 0.47-0.49v.
Also took picture of board showing three small red LEDs light dont know if this is relevant but, to much information may be better than none. Hope this helps.
and the screen said that was around 200 degrees i expect? That suggests your mightyboard is fine, and the problem is elsewhere.
can you take a photo of the component side of your HBP? you’ll need to take it off for that.
Some great enhancements, already planned to upgrade parts as viewed on you tube.
I have only printed out parts from thingyverse using Pla on a cold platform due to iissues with the HBP but, this seemed to work didnt know I had a fault till trying some ABS when I discovered cold and ABS dont mix. Printed load of bits but found I needed to print on a raft ( until recently thought that was something that floated on water! but, thanks to people like yourself I hope I`m starting to learn a thing or two. Just need to get things up and running properly before sending for more bits such as the extruder feed device which I ordered.
Thanks
Hello again,
Here are the pictures as requested gather you meant the side showing the solder tracks hence taking it of the mounts?
If Ive given wrong pictures then Ill retake later.
Thank you your efforts are appreciated!!
Just realised the pictures you wanted are of the HBP (Fool I should learn to read properly!!)
Here are the correct images I hope.
472_resistor_and_capacitor_ctc_hbp.jpg 472_restistor_and_capacitor_above_shot_ctc_hbp.jpg win_20170225_204534.jpg led_and_102_resistor_ctc_hbp.jpg
