Nov 2015
Hi, (before I start I’d best say I’m not new to 3D printers, and I have two other printers at home an Ormerod and a Prusa i3). Ok I have a few questions about upgrading the Dual’s Firmware. I’m using the Makerware 3.8.1.231 software, and recently upgraded the Firmware to 7.5. I’ve only had the printer a few days now, but it’s x3g files aren’t anything like the GCode I use on the other printers. Anyway, I plan to Re-install the Firmware starting back on 7.1 (which is what it seemed to come with) because I’ve found I can no longer read SDHC cards. It reads the 2Gb SD card that came with the machine fine, just won’t see SDHC cards any more. I suspect it might have been me upgrading to 7.5 and not realizing that actually beeped etc when the upgrade had completed. Is any one else running 7.5, and are you having issues with SDHC cards. The printers been running fine with 7.5 apart from that. Also I’ve always had an issue with the Bed temp reading being 20’ higher than it actually is. I hope to install SallyFish once I have this SD card problem behind me, but it’s just a case of How at the moment…?
Thanks in advance for your help guys.
Kim…
(PS You will find some of my designs up on Thingyverse if your interested…Try 1133469)
    Nov '15
    May '19
  • 13
  • 22.8k
  • 6
You need to install sailfish this is because .5 firmware is designed to make about 3-D printer is not CTC clones once updated to sailfish it willread any size SD card fine the only problem is makerbot 7.5 does not support the CTC printer that includes any firmware form makerbot desktop that’s why it will not read the SD card also sailfish has a variety of other features than stock, btw you can’t downgrade to ctc 7.1 as its a firmware only they have so sailfish is your only option.
Hi Dan, thanks for the info… Ok I wanted to put Sailfish on the machine in any case. Your right about the 7.1 not being available, I re-installed 7.0, then each upgrade back to 7.5. The SD card still didn’t want to know SDHC cards, but otherwise it works fine.
Can I install Sailfish via the Makeware software? I think I saw someone had set the machine type to replicator, installed a Sailfish version, then changed the machine type to the Dual and carried on with the final install. Any advice warmly welcomed… Many thanks for your reply.
Kim…
3 years later
8 months later
Resurrecting an old post, but did the OP find out why the bed temperature was over reading by 20 deg ?
Mine is the same after installing Sailfish. During installation the bed heated up high and I thought maybe this had damaged something ?
