Jan 2016
Hi, I’m from the UK and bought the above printer off eBay new 12 months warranty for xmas for my son, all has been working fine but the right extruder has now stopped heating up ! I’m having no luck at all with the company i bought it off even tho it looks like it is CTC directly who sold it.
If i get no where with them what can I do to resolve the fault. If i put a hair dryer on the end the temperature goes up on the LCD and FET1 is green but FET2 doesnt come on. when the left one is working FET3 goes green then FET4 goes green when the temperature goes up. Any Ideas ? Many Thanks
    Jan '16
    Feb '16
  • 16
  • 1.5k
  • 4
It’s either the Transistor which is broken on the printers motherboard, the heating capsule, or both. As it’s easiest to test I would try connecting the left heating capsule to the right connection on the board, then let it heat up for a moment and see if something works. If yes just order a new heating capsule, they are sort of limited in the amount of service time anyway and not very expensive. If it doesn’t heat up it is probably going to be a bit more work.
Top drawing is the front, lower drawing is the sides. There is a notch there because there is a set of nuts and bolts that block the acrylic from being flush.
