I think if you put on too much thermal paste and it bridges the tiny gap on the tube that acts as a heat break, it will sink too much heat from the hot end. Try cleaning the tube off with alcohol and a QTip. I put one on my printer and realized this would be a problem if I over did it. Mine holds temp well.
I think heater cartridges fail totally, and an open thermocouple would be pretty obvious causing thermal runaway or other error. Most likely it is a heat sinking problem associated with the thermal grease. Please let me know.
Ed
If all the checks from Ed and Tom don’t work out then try setting both nozzle temperatures to 195 and see if they both get to that temperature. If there is an offset of roughly the same temperature difference when you set both nozzles to 160, then it may be thermistor or software related with firmware. I’ve had my firmware go haywire on me before after both long prints and a cold boot. The software issue is far fetched I know but it shouldn’t be ruled out entirely yet. I wish you good luck and hope to hear back from you soon.
I checked the thermocouple and they are fine,
I removed all of the thermal paste, still no change,
the right extruder slows down around 160C and falls behind 10C to the left one then cant go above 210, the left extruder can go to 250C but really slow, nether can maintain the temperature, they fall 3C short and just stay at 192C,
the lcd pannel is kinda glitchy, missing a random letter once and a while and for a while the printer started up with a blank screen instead of the sailfish info, after I added the new nozzles.
If the thermocouple is good and you removed some thermopaste then it might be software. One last question when you heat the nozzles the issues you have are when they are hearing stationary and not moving right? I notice that with my stock hotness with the Hercules full metal nozzle I can’t get higher than 250 and when the nozzles move while printing they go lower because of the air cooling it down. If the issue is while you are heating before a print then I would say a big finger is pointing towards software. It seems that when your firmware reads the thermocouple reading it’s either not reading it correctly or something wrong with the heating functional in code.
Do you have a stable 24 volts from the power supply? Are the power leads from the supply tight? Were you getting display glitches before the hot end changeover? Have you tried using one extruder at a time? It sounds like a current issue now (no pun intended).
Just thought about another test you could try; try moving the thermocouple wire while taking a reading with your multimeter at the end that connects to the motherboard. Check to see if there is no break in the wire that may cause the thermocouple to disconnect every time it is moved. I know my x axis homing switch had the same issue and couldn’t find the problem until I tested the connector that connects to the motherboard and move the sensor wire. Find the issue and it was an easy solder job. I’ll be waiting for your response
Good point I didn’t think o ask about whether his firmware was glitching before or after the change. Nice catch!
Also can you provide us with the sailfish version you are running I’ll check the changelogs to see if a newer firmware fixed a problem like you are having
Sailfish F CreatorX
Thing 32084 14/11/05
Sailfish v7.7 r01234
That’s what the panel says.
all connections are sound. solid 24v
It can heat the bed and both extruders all at once, the bed works fine, and the extruders heat the same way if you do either of the three or all of them.
Ok so you have the latest stable release. There is apparently 7.8 version released but it hadn’t been widely adopted yet so wouldn’t recommend upgrading unless you really feel the need to. Changelogs don’t mention hotends issues either.
Are the set screws tight on the heaters? Unrelated, but were there display glitches before the changeover? The loose wire while printing theory is good.
I have an extra fan to cool the part that also tends to cool the extruder. Are you using one?
I wiggled the wires like crazy on the thermocouple and they are fine.
Only after I change nozzles is when the panel went strange, but the panel appears to have fixed itself now.
I don’t have an extra fan
Hmm that is strange… The only thing I can think of is that the extruder with the lower temp is not getting the same amount of current to heat the hot end. That’s the only other thing I can think of. I mean the wires are good your getting correct voltage. The thermocouples are tested. Only other thing other than firmware is the current going to the hot end. If you can check the current that would be something else we can rule out. I don’t think they go over the 10 amp max on most amp meters so my suggestion is test the current on both and compare to see if they are both in the same ball park. Do this especially at around the 195 degree threshold when the faulty nozzle doesn’t heat more.
Did you update the power supply? You may not have enough watts now. I think you can do that upgrade with a 220watt, my 120 can barely hold the temp on both nozzles and plate simultaneously.
I have a stock NES-350-24 power supply
The flashforge comes with a 300 watt power supply though so it should be good enough to heat both nozzles. I also think that if it were the power supply not providing enough wattage we would probably see both nozzles not reaching the desired temp.
