all connections are sound. solid 24v
It can heat the bed and both extruders all at once, the bed works fine, and the extruders heat the same way if you do either of the three or all of them.
Ok so you have the latest stable release. There is apparently 7.8 version released but it hadn’t been widely adopted yet so wouldn’t recommend upgrading unless you really feel the need to. Changelogs don’t mention hotends issues either.
Are the set screws tight on the heaters? Unrelated, but were there display glitches before the changeover? The loose wire while printing theory is good.
I have an extra fan to cool the part that also tends to cool the extruder. Are you using one?
I wiggled the wires like crazy on the thermocouple and they are fine.
Only after I change nozzles is when the panel went strange, but the panel appears to have fixed itself now.
I don’t have an extra fan
Hmm that is strange… The only thing I can think of is that the extruder with the lower temp is not getting the same amount of current to heat the hot end. That’s the only other thing I can think of. I mean the wires are good your getting correct voltage. The thermocouples are tested. Only other thing other than firmware is the current going to the hot end. If you can check the current that would be something else we can rule out. I don’t think they go over the 10 amp max on most amp meters so my suggestion is test the current on both and compare to see if they are both in the same ball park. Do this especially at around the 195 degree threshold when the faulty nozzle doesn’t heat more.
Did you update the power supply? You may not have enough watts now. I think you can do that upgrade with a 220watt, my 120 can barely hold the temp on both nozzles and plate simultaneously.
I have a stock NES-350-24 power supply
The flashforge comes with a 300 watt power supply though so it should be good enough to heat both nozzles. I also think that if it were the power supply not providing enough wattage we would probably see both nozzles not reaching the desired temp.
nothing looks odd with the voltage,
there is this red light on the board that’s on and under it it says y-min and overheat? is that something? or is that normal?
this is what it looks like on the board []=light [1]= the red one on
Y-MIN
R91[] [1]
overheat
[]R109
Can you heat only 1 nozzle at a time? Can both reach and hold the desired temperature alone?
Tom
Darn not at my flashforge right now. I’ll look to see if someone posted a video on YouTube real quick.
Try speaking to Mr.Tang from flashforge. He might have more information on the debugging process for the motherboard lights since I can’t find anything on YouTube other than a video showing the motherboard powered off.
So I found a Google blog post stating that the overheat light is no longer used for overheating but for the 5v bus according to here: Redirecting to Google Groups so it seems you can ignore that led.
Is the overheat light flashing or on steady? The google post I mention below states that if it’s flashing you have a problem which would affect the hot end.
The red light is solid.
Both nozzles will heat up to 192/195 but wont get to the desired temperature.
At this point I think testing the current going to both hot ends is needed to pin down whether correct wattage is present. Since you have the necessary 24 volts the next step is the current. If something in the heating circuit is defective you should be able to to see it when testing both the voltage and current. Since the voltage is fine the next step is checking the current. Try putting an amp meter in series with the wire connected to the hot end. Most voltmeters these days have a setting for testing the amperage. You should set it to 10 amps for testing I am just worried that the current going to the hot end is higher than 10 amps and you burn out your amp meter. If anyone else has the specs to ensure he doesn’t burn his amp meter please chime in.
Both have the same current in and out,
However the left nozzle that can heat to a higher temperature uses 1.39 at first then declines to 1.34 and then when its 5C from the target temp then fluctuates 1.00-1.32 and the right one uses 1.43 all the way, do you think the heating cartridges are not accepting what power they need?
