Mar 2015
Did you post this on the Ultimaker forums? There are quite a few people who print with bronzefill no problem there. I love the idea from Steve here that it might be clogging the knurled wheel in the feeder. Compressed air usually helps (or blow hard). Maybe it’s time to print out that IRobertI feeder. My first thought though was that if you are switching between ABS and PLA regularly you are bound to have problems. ABS needs things hotter and the teflon isolator tends to deform which ABS doesn’t seem to mind as much and then you switch to PLA and you have a deformed isolator which causes extra friction (a few pounds!) and you have some bits of ABS in the nozzle slowly caramelizing over the next few hours.
I do a “cold pull” aka “atomic pull” after EVERY filament change to get every last microgram of the old filament out. This means that whenever the printer finishes a print, if I suspect I might have to change filament I immediately set the nozzle temp to 90 for PLA (or 130 for ABS) and shove the filament back into the nozzle while the nozzle is still hot then come back later when the bed is cool and pull the filament out. I still have the original feeder also and this would be easier with the IRobertI feeder.
Cleaning is always a good idea, but especially after printer filaments that have particles in them.
You have to think about the fact that these materials (at least the ColorFabb ones: BronzeFill, CopperFill, WoodFill, BambooFill and soon BrassFill) are based on PLA.
When you start to have printing problems and the materials stays inside a heated nozzle for a longer time, the PLA will start to move out from between the particles (metal or wood) and this will lead to a clump of particles which can be hard to clean.
But if you don’t clean your nozzle completely, these particle-clumps can lead to random blockage later on as one of them will come free and try to come out through the nozzle.
At ColorFabb they print these materials mostly with regular feeders on their Ultimaker 2’s.
It works quite well once you have the settings dialed in.
Also keep in mind that printing to slow can cause troubles as well.
Most temperature settings are designed for the regular speeds (around 50mm/s mostly) and printing really slow may cause additional heat to travel up trough your hot-end and will cause the filament to start melting (and thus expanding) higher up in the nozzle.
This will then lead to additional friction inside the hotend.
If you are still having problems, just send ColorFabb a quick email to support@colorfabb.com.
They’ll be happy to help.
lol. You too! It’s impressive how many people on the UM2 forums are also here.
If you click on the /ColorFabb tag here you’ll enter the ColorFabb sub community. There’s a couple of Bronzefill posts there as well. That might also be of help. Cheers
28 days later
I never had problem with bronzefill. It’s all about speed and temperature. You must know more about material. At the first clean your nozzle, use aceton, water, burn nozzle, hot wire. Try again if is not blocked. If not, see official website which temperature is correct to use and test it with printer. Jammed nozzle means bad speed with bad temperature or material flow. Ultimaker is powerfull printer and you are able to change almost everything during print. Try it.
Thanks wonderdax,
I did all of this already and now the printer is running fine.
Ciao
Alfred
